mrz plz !!!!
i use mikrotik v3.13 on pc i have hotspot and
i have error in this script its if he found the name in the dns cache he put it in wep proxy and when the scrept run again he Repeat the name in the wep proxy like the pic
and this is the script
:foreach i in=[/ip dns cache find] do={:local bNew “true”;:local cacheName [/ip dns cache all get $i name] ;:put $cacheName;:if (([:find $cacheName “mikrotik”] != 0) || ([:find $cacheName “cnn”] != 0)) do= {/ip proxy access add dst-host= $cacheName redirect-to=google.com};:if ( $cacheName = [/ip proxy access find dst-host=$cacheName] ) do={:set bNew “false”; }}}}
and i need another script if i have many user like:
1- name=a profile=dufalt
2- name=b profile=new
3- name=c profile=dufalt
4-name=d profile=dufalt
5-bame=e profile=new
i need script to put it in user profile script onlogin do if the user login set profile=another profile
and thankes for any help
i tray to do this but ihave small error
:foreach i in=[/ip hotspot user find profile=defalt] do={:if ([/ip hotspot active get [find user=[/ip hotspot user get $i name] uptime <1m ]) do={/ ip hotspot user set [/ip hotspot active get $i user] profile=30}}}
??? :frowning: :frowning:
??? :frowning: :frowning: :frowning:
You have to check if entry is already added to proxy access. Check this example:
http://wiki.mikrotik.com/wiki/Scripting-examples#Block_access_to_specific_websites
It uses address lists, but concept is the same. Compare if entry is already added, if not then add.
first thanks for your answer
but i need to add in proxy dont add in firwall
:local bNew “true”;
:put $cacheName;
:if (([:find $cacheName “rapidshare”] != 0) || ([:find $cacheName “youtube”] != 0)) do={
:local tmpAddress [/ip dns cache get $i address] ;
:put $tmpAddress;
if address list is empty do not check
:if ( [/ip firewall address-list find ] = “”) do={
:log info (“added entry: $[/ip dns cache get $i name] IP $tmpAddress”);
/ip firewall address-list add address=$tmpAddress list=restricted disabled=no comment=$cacheName;
} else={
:foreach j in=[/ip firewall address-list find ] do={
:if ( [/ip firewall address-list get $j address] = $tmpAddress ) do={
:set bNew “false”;
:if ( $bNew = “true” ) do={
can you help me ??
thanks i do it :laughing: :laughing: :laughing:
:local bNew “true”;
:put $cacheName;
:if (([:find $cacheName “adult”] != 0) || ([:find $cacheName “porn”] != 0)) do={
:local tmpName [/ip dns cache get $i name] ;
:put $tmpName ;
:foreach j in=[/ip proxy access find ] do={
:if ( [/ip proxy access get $j dst-host] = $tmpName ) do={
:set bNew “false”;
/ip proxy access add disabled=no comment=$cacheName dst-host=$tmpName action=deny ;
