currently i have aproblem which happends to my isp customers,…-
msn messenger is not connecting, unablke to log in from all my customers computers..
yahoo messenger,skype and all other meesenger applications..
i had noticed days ago that if i limited client connections msn woudnt work..
i did disable that rule now but msn still not works..
just msn messenger since i can check emails from hotmail.com i know the problem is only with msn messenger.
You must check your firewall configuration. All the ports used by msn must be opened.
This is the list of the ports used by msn:
-80 (tcp) : Conversation, games
-1863 (tcp): Conversation
all those ports are open, it happends that in some computers msn is working and in others not… i did reinstall msn on the ones not working but is the same …
could it be the ethernet adapter of the ones not working the problem??? coulkd it be possible even though the pc is surfing?
You may use torch to track down the addresses and traffic that uses your upload, make sure that these ports are opened and you are using 2.9.46 version.
