MSN Problem
Hello every Body. Well i have a question and i dont know if it is dummy or silly or serious, but can i prioritize the connection for msn messneger???Hope that my idea is clear
Yes, you can.
You would need to find out what ports that MSN Messenger works on. Then you can use queues to prioritize all traffic, and give the MSNM queue a higher priority (lower number) than the other traffic.
well i would be thankfull if the configuration could be posted cause i am new to this. also i am limiting my costumers using pcq can this be done along with the pcq limits. thanks in advance.
