MSN & Secure Sites Issue
I Run MT 2.9.24… have 4 wired interfaces, using 3 of them.. a couple PPP-in VPN tunnels and a dchp server and not traffic shaping for the network at my dad’s business… but yesterday 11/21/06 the router quit letting them use services like MSN…or royalbank.ca/onlinebanking…
or messenger.msn.com…i swapped in a wired gnet router and it works fine…
not sure what to think :confused: any ideas?
Tyler
check MSS rule
I am not able to Login to MSN, YahooMail and any secure SSL websites after I have upgraded the RouterBoard latest version 2.9.37 patch.
Previously on RouterOS version 2.9.29 seems to works fine!
Where can I download the older version Router OS version and how do I revert back to the old patch version?
I need the old “all_packages_2.9.29-ns.zip” package for the RouterBoard downgrade? Can anyone please help?
Thanks.
rodney
(newbie)
Do you have a change-mss rule in ‘ip firewall mangle’? If not, then put one in and try values of about 1300 to start.
Regards
Andrew
Well, I did that with no luck! Must be some other relating matters in my configuration on the RouterBoard.
Thanks anyway for the tip!
Regards,
Rodney
