We have a ring with 10 CRS317-1G-16S+/r2 switches on v6.47.9 (factory default)
The switches are alternatingly connected with a single fibre cable and a 802.3ad bond of 2 XS+DA0001 interfaces.
Hardware Offload is enabled/working.
When enabling MSTP, the correct ports are being “blocked” (alternate/not forwarding) per MSTI.
We however see that the VLANs in question are not being blocked at all. Traffic is flowing through the alternate port.
Config snippet:
add frame-types=admit-only-vlan-tagged ingress-filtering=yes name=CORE priority=0x7000 protocol-mode=mstp region-name=XXX vlan-filtering=yes
/interface bridge msti
add bridge=CORE identifier=11 priority=0x7000 vlan-mapping=3051,3054,3055,3056,3261,3262,3316
add bridge=CORE frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=SWITCH_INTERCONNECT
add bridge=CORE frame-types=admit-only-vlan-tagged ingress-filtering=yes interface=sfp-sfpplus10
/interface bridge vlan
add bridge=CORE tagged=SWITCH_INTERCONNECT,sfp-sfpplus9,sfp-sfpplus10 vlan-ids=3316
As expected with our config, sfp-sfpplus10 is an alternate port in MSTI 11. We would expect that this is blocking VLAN 3316, but we are seeing traffic passing on this VLAN.
/interface bridge> monitor 0
state: enabled
current-mac-address: 2C:C8:1B:71:6A:43
root-bridge: no
root-bridge-id: 0x4000.48:8F:5A:82:2B:16
regional-root-bridge-id: 0x4000.48:8F:5A:82:2B:16
root-path-cost: 0
root-port: sfp-sfpplus10
port-count: 5
designated-port-count: 2
mst-config-digest: cc9030cbf2e92a2d952a31e20e87283b
fast-forward: no
/interface bridge port> monitor 2
interface: sfp-sfpplus10
status: in-bridge
port-number: 3
role: root-port
edge-port: no
edge-port-discovery: yes
point-to-point-port: yes
external-fdb: no
sending-rstp: yes
learning: yes
forwarding: yes
internal-root-path-cost: 30
designated-bridge: 0x8000.2C:C8:1B:71:64:51
designated-internal-cost: 20
designated-port-number: 1
hw-offload-group: switch1
/interface bridge msti> monitor 1
state: enabled
identifier: 11
root-bridge: no
root-bridge-id: 0.00:00:00:00:00:00
regional-root-bridge-id: 0x400B.48:8F:5A:82:2B:16
root-path-cost: 0
root-port: SWITCH_INTERCONNECT
port-count: 5
designated-port-count: 1
/interface bridge port mst-override> monitor 6
port: sfp-sfpplus10
status: active
identifier: 11
role: alternate-port
learning: no
forwarding: no
internal-root-path-cost: 220
designated-bridge: 0x800B.2C:C8:1B:71:64:51
