MSTP Support?
Since MSTP support has been added to RouterOS, is there any chance we will be getting it for SwOS too?
Currently trying to setup a CRS326-24G-2S+ (SwOS 2.7) and it only has RSTP, which makes it rather hard to make advanced VLAN networks.
One year later but I have the same question. Will be MSTP supported in further versions of SwOS? We are finding new switch vendor and MSTP is necessary feature.
Thanks for the suggestion!
MTSP support in SwOS will not be implemented in the near future. SwOS is designed to be a simple management tool so that users can create basic networking setups. For more advanced configurations, you should stick with RouterOS.
