Dear Mikrotik People,
hello Forum,
we are a german-based ISP and we plan to invoke several software-based routers on some of our
locations. we plan to use Mikrotik RouterOS as edge routers with BGP peers to our upstream and
peering providers. we want to connect these edge routers to our Core L3 network, using trunked
gigabit links (802.3ad LACP), and we want them to be stable, resilient and fast.
As for now, i’ve got some questions, that i don’t want to ask the support staff only, but also
the community that has already deployed MT Router solutions and actually lives with them:
- Experience in edge-networks (Upstream/Peering >1gbs+)
Are there any people that use MT router in upstream or peering situations that cover
1gbps+ bandwidth? What are your suggestions on behalf of cpu and hardware?
- forwarding rate @ p4 3,0ghz
- with and without firewall
as an example, p4 3,0ghz with intel quad 1000 MT gig ethernet will be used as single transit
router to our primary upstream. what can we expect in terms of packet rates that the router
still can handle?
what impact on the forwarding rate does it have that no HT or SMP can be used?
whats the reason MT can’t handle dualprocessors?
2) Kernel used in MT software
We are interested in getting to know what kernel version the RouterOS 2.9 is based of.
do they base already on 2.6.?
Is there NAPI support for intel 1000Mbit/s adapters in MT?
3) BGP implementation
As we must rely on our BGP network, i’m specifically interested in the BGP implementation
of MT. is there support for communities, filters, path prepending, route-maps and all the
other “more-deep” stuff? do we have some kind of logging status of our neighbor connections?
can we even syslog that to another (external) syslog server?
4) iBGP & VRRP on same interface
As mentioned, we want to use several MT peering / upstream routers, that consolidate traffic
on our core L3 network. we want them to speak with each other peering router via iBGP, and
gateway backup should be done via VRRP. is that possible on the same (bonding) interface,
that looks towards the L3 core?
I’m really looking forward to gathering more information about this promising project.
I would love to hear from people that actually use MT routers in production for similar
purposes.
Routing people - would you advise changing edge routers to MT? right now, our overall network
load peaks up to ~200 Mbit/s, with roundabout 40-50kpps. We plan to raise that load soon.
Thanks,
Frank
