hi, sorry for my english
mikotik uses for pptp termination.
mikrotik ros 3.20 installed on 2 x intel dual core xeon 3ghz & 2x intel pro1000 server adapter. when active sessions (pptp) > 250, MT have some “lags” and drop sessions.
to example
now mt 3.20 works fine with Intel core2duo (2x3ghz) >400 pptp sessions, but processor loading over 95%
Upgrade to the latest RouterOS version. Some users have reported that fixed similar problems. Not to mention it has dual core improvements and pptp imrpovements! It’s easy
I see in your first post (not clear but ~understandable post) that the Xeon CPU is 3000Mhz ? So the system has 2x3GHz Xeon CPUs and the Core2Duo@3Ghz outperforms it? Hmmm… How did you test that performance ? What exactly are you comparing?
