MT 3.6 webproxy
hi,
i have 2 MT 2.9.27 with webproxy enabled and cache drive is “system” and i want to upgrade to 3.6 but first i want to know if the new web proxy will still use the old cache files cz i don wanna lose my cache files.
and can we copy the cache files from one drive to another with clone operations ?
best regards
no your previous cache will not help with Ver 3 web proxy, the ver 3 web proxy will start a new cache for you. and BTW if you want to upgrade your MT version 2.9 to 3 then first clear your previous web proxy cache cause it’ll not help with the ver 3 web proxy.
thank you very much for ur reply.
if i have a secondary cache drive n MT3.6 with 30 gbs cache files in it ,can i clone it in another hdd and put it as cache drive for an another MT 3.6?
best regards
Sorry dude, I have no idea about that. ask MT support team or tech team for that.
hii there i just wana sk you something.
if anyone know how to config the mikrotik to bypass cash object in another word the cash files will not be queued and would deliver at maximum speed to the clinets when they request it, can any one help me :frowning:
If you want to deliver the cached content as fast as possable, then yes, its called a TOS bit..
ali_hacker, I’m using that setting in my MT web proxy cache and it’s work just cool like you said. I’ll be back to you get to go now.
Thanks and brb
gmsmstr , what about the TOS if you can please provide me with explain for this option cause i have a very little information about it
hulk-bd , i will wait for u when u will be back and i want the information if you could gave it to me :smiley:
ali_hacker, you can mark the output packet from mkt proxy to client with TOS in DSCP in V3.x to put it in simple queue with high priority.
can u show me how plz.
best regards
patagonia , thanks for th information but i dont know how to make such rules if you can please put an example here and we will be so gratefull for the informatin, by the way im using vpn connection
yeaaaahooo i finally did it now my MT web proxy is working as good as i want him to
so thank u guys for your help
now i can bypass the cashed objects which available on MT router and deliverd as maximum speed to my clinets and those objects won’t be queued (BYPASSED)
yea im feeling happy :smiley: :smiley: :smiley: :smiley: :smiley: :smiley:
can you post your proxy config on forum?
thanks,
Steven
