I try to run an ACCESS POINT with 4 sectoral antennas.
But, I can not get it when I install the third antenna.
If I run the third, then one of the first or second antenna will disconnect.
All goods are coming from MikroTik.
What should I consider in implementing such thing ?
eg. all vertical antennas or must be different, distance of each antennas, etc.
