I have several MT routers with VIA Epia and Athros running. Works like a charm ![]()
Michaelg
Michaelg
Thank you very much!
Can you let me know exactly which VIA board?
I was thinking of using the EPIA5000
Also, which PCI:MiniPCI adaptors do you use - ones from MT?
And how many radio cards, 1 or more?
Many thanks & kind regards
Stephen
Mainbord: EPIA-V8000 and EPIA-V10000
Low power consumtion and low heat.
Uses powerkit and POE injector ; http://www.highgreen.nl/products/dcpower/power.asp?id=15198&supplier=1000
With PCI riser card and Routerboard14 adapter you can use up to 8 wireless minipci cards.
My routers works fine with both Mikrotik brand Atheros and other Atheros based 5211 and 5212 cards (my experience is that the MT brand is more stable). Also PRISM cards works fine.
rgs
michaelg
