MT and Proxim Tsunami 5Ghz?
Does it help me if buy level 6 license, did they communicate between?
any ideas?
I have an MT in range of a Tsunami unit and the latter does not show up in an MT scan.
No, totally different protocols. MT is open, MP11’s are proprietary!
So there is no way to get connected MT 5GHz client to → P.Tsunami MP11 AP?
all proxim products use turbocell protocol (by proxim and karlnet) and are propietary. Only conect with same model and license.
How bad has the interference/noise been between MT and Tsunami products operating near each other?
none at all, of course we’re using different frequencies. But this is a very good topic, since the MP11a’s stop working if you try to use the same frequency, as opposed to other equipment that show other symptons. The MP11’s have a system that allows the Base to modify the SU’s in case of interference, so it’s a smart system that works well.
How about the Tsunami PTMP system and Mikrotik?
SMA
same thing!
Diid you mean it is the same answer for both systems, or did you mean you thought it was the same product. If the latter, I meant the older Tsunami PTMP (20/60) system, not the current Tsunami MP.11A system…
SMA
Same answer for both/all proxim products. They’re not “new”, they’re actually pretty “old” on the market with revisions. Just now we can afford them.
