Hi All
I’ve been trying to setup a WG VPN for almost a week following mainly this topic https://forum.mikrotik.com/viewtopic.php?t=182340 but I really need some expert’s help.
My use case:
- I’ve successfully set up a WG Interface on an Ubuntu instance on Lightsail. I can connect my phone and 2 PC, they can ping each other and I can access the webserver between them. 10.8.0.1 is the IP I choose for the WG on Ubuntu.
- I know need to use the WG tunnel to access devices at home through a web browser (I can access them via browser when on local LAN)
- At home I have a MT (HAP AX3) connected to Eth1 to my ISP provider (MT is working correctly and provide Wifi access). MT have a 192.168.88.1 address while 192.168.1.1 is the ISP modem.
I also created a static route
I know it’s not an issue with WG but with firewall and/or routing. Please help me or point me in the right direction.
Thanks in advance!
Current situation as per below OS Config:
a) I can ping WG MT IP from other peer and I can ping other WG IP clients (in and out seem to be working)
b) From remote peer I cannot ping devices within MT LAN using their IP. I can only ping MT Interface IP.
My RouterOS configuration:
RouterOS 7.11.2
add admin-mac=XXXXXXX auto-mac=no comment=defconf name=bridge
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-BAE354 \
disabled=no security.authentication-types=wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-BAE355 \
/interface wireguard
add comment="WG Interface" listen-port=51820 mtu=1420 name=wgM
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
/routing table
add disabled=no fib name=useWG
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add comment="WG Interface to WAN" interface=wgM list=WAN
/interface wireguard peers
add allowed-address=0.0.0.0/0 comment="wg Peer MT" endpoint-address=\
XX.XXX.XXX.XXX endpoint-port=51820 interface=wgM persistent-keepalive=25s \
public-key="MYPUBLICKEY"
192.168.88.0
add address=10.8.0.5/24 comment="wg MT Address" interface=wgM network=\
10.8.0.0
/ip dhcp-client
add address=10.8.0.5/32 comment=LAN-4-WG dns-server=8.8.8.8 gateway=10.8.0.1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="WG - Allow UDP" dst-port=51820 \
protocol=udp
add action=accept chain=forward comment="WG Fwd Local traffic to WG Tunnel" \
out-interface=wgM src-address=192.168.1.0/24
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=established,related disabled=yes hw-offload=yes
connection-state=invalid
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/routing rule
add action=lookup disabled=no src-address=192.168.88.0/24 table=useWG
/system clock
set time-zone-name=Europe/Rome
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
