hello all,
i’m trying to setup my MT router as pptp server…
The router has a wireless interface, and two ethernet.
the first ethernet is connected to the localnet (where dhcp server runs), and the second is connected to the adsl modem.
first of all, i setup the pptp server…
/ interface pptp-server server
set enabled=yes mtu=1460 mru=1460 authentication=mschap2,mschap1 keepalive-timeout=30 default-profile=test
second, i made a ppp profile:
/ ppp profile
set default name="default" local-address=0.0.0.0 remote-address=0.0.0.0 session-timeout=0s idle-timeout=0s use-compression=no \
use-vj-compression=no use-encryption=no require-encryption=no only-one=no change-tcp-mss=yes tx-bit-rate=0 rx-bit-rate=0 \
incoming-filter="" outgoing-filter="" dns-server="" wins-server="" comment=""
add name="test" local-address=dhcp_pool1 remote-address=dhcp_pool1 session-timeout=0s idle-timeout=0s use-compression=yes \
use-vj-compression=no use-encryption=yes require-encryption=yes only-one=no change-tcp-mss=no tx-bit-rate=0 rx-bit-rate=0 \
and third i created a test user:
/ ppp secret
add name="test" service=any caller-id="" password="test" profile=test local-address=0.0.0.0 remote-address=0.0.0.0 routes="" \
limit-bytes-in=0 limit-bytes-out=0 comment="" disabled=no
I’m trying to connect from windows XP, log file writes “PPTP connection stablished from xxx.xxx.xxx.xxx”, but the connection stops to “verifying username and password”..
After few minutes, winXP reports an error 619.
So, where did i go wrong ?
