MT Backup/Restore silly joke !!!!
Hi guys.
Last night was a long night of work for me. This is why.
I found out that the hard drive of my router was dying (the led was always on, and the router didn’t seem to be able to write to disk). So i restarted it and it turned on and MT loaded up (the hard drive was also making the unmistakeble sound of failure). I tried to make a backup through winbox and it did it, so i transferred the backup to my PC. I changed the hard drive and reinstalled MT. Until here everything was fine.
I copied the .backup file to the router and tried to restore it, but here everything comenced to go bad. I got a message “cannot restore, file too short (6)”. I tried to reupload the file and do the restore from telnet. No luck.
I found a older .backup file of my router (made months ago) and tried to restore it, no luck again “file to short…” message kept showing up.
So i decided to reconfigure the router from scratch, and it took to me 4 hours… :frowning::frowning:
This made me think.
Wouldn’t it be nice to have a tool that tests the .backup files and maybe repair them?? And again, wouldn’t it be nice that the .backup file be in plain text format, like a .conf file (so when something goes wrong you can at least read part of the configuration from a damaged .backup file???
What do u think?
yes. A textfile would be real good. I dont expect it to be as short as
cisco configs are. But it would give us a chance to handle this file
and have a chance in our darkest hours :wink:
Of course you should be aware that hard discs are dying. It’s just
a matter of time. So some hints to avoid this situation:
  1. No Harddisc (flash memory has a chance to live longer)
  2. Mirror Disks
  3. Vmware. Have you tried to run ROS in VMWare Server?
    This gives you the flexibility to move your router around, snapshot it, …
Stefan
well well .. please read the manual:
http://www.mikrotik.com/testdocs/ros/2.9/system/management_content.php#.61.3
RouterOS does have a text conf file, and you should use it for backup purposes. the backup file ‘too short’ probably means it was corrupted, or it didn’t finish making it.
Well Normis. You are so right. I’m begining to become these lazy persons that ask before reading.. :frowning: :frowning:
In the future i’ll try to read more.
Many thanks.
Best regards
And why have a button labeled “backup”?
The txt export comes out in the wrong order for an import if done from the root.
clarify please
