MT bridge capabilities
Please look @ picture here below, used to detailed my post
Rgds
No, this configuration would not work correct (2).
As you have bridge, you need to setup PPPoE server to bridge, but bridge should not include public/outgoing interfaces when PPPoE server is configured.
And you must to use proxy-arp
Maximiliano
how can we put a public IP at the client PC , so he will not be NATTED ?
let’s say 2 interfaces , wan and local , with public gateway a.b.c.1 , the wan is a.b.c.2 , now can we give the local interface a.b.c.3 ? is there a way to do this ( a real IP on the client PC )
IP address a.b.c.3 is not assigned to lacal MT interface, as you can see from picture, but directly to Costumer’s PC, and int is in the same subnet of a.b.c.1 (ISP public IP address) and a.b.c.2 (MT IP WAN address).
