I set up the same masquerade for the 10.0.0.0/24 network on my MT box with two interfaces. The masq would only work for one interface at a time.
Is this a bug? Version 2.8.17.
Do you have 10.0.0.0/24 subnets on both interfaces? If so, you can only do this with the interfaces bridged.
I’m stumped as to why you would even want to run 2 interfaces on the same subnet..
Because I’m combining two previously seperate AP’s into one MT unit with two wireless interfaces that both have clients on the same subnet.
If the interfaces are bridged, is there anyway to keep them from talking to each other (or clients from talking to each other on the same AP aka Intracell communication)?
it is far more simple!! in wireless ap setting set default-forwarding=no and the clients will not be able to talk to eachother
Okay, that is the first part of what I was looking for!
Now, is there a way to make an exception to this rule for a couple of clients on that interface (probably not I’m guessing).
And, what is the rule or procedure to set it up so that the clients from one interface can’t talk to the other interface when they are bridged?
