MT & Cisco EoMPLS Config
Hi All,
We currently have a network running Cisco MPLS core with Mikrotik PE for handing off EoMPLS (VPLS) pseudo wires. At our major POIs I would like to move away from MikroTik to have a Cisco 3750ME or Cisco 6500 as our PE.
I have followed this guide: http://wiki.mikrotik.com/wiki/Manual:EoMPLS_vs_Cisco
whilst testing between a MT 2011 & Cisco 3750-ME however cannot get the tunnel to come up.
Config:
Cisco 3750-ME
pseudowire-class l2vpn
 encapsulation mpls
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet1/1/1
 no switchport
 ip address 172.16.1.1 255.255.255.252
 ip ospf network point-to-point
 speed auto 1000
interface GigabitEthernet1/1/2
 no switchport
 no ip address
 speed auto 1000
 xconnect 2.2.2.2 173 pw-class l2vpn
router ospf 1
 router-id 1.1.1.1
 log-adjacency-changes
 network 1.1.1.1 0.0.0.0 area 0
 network 172.16.1.0 0.0.0.3 area 0
mpls ldp router-id Loopback0 force
RB2011
/interface bridge add name=lo0
/ip address add address=2.2.2.2/32 interface=lo0
/ip address add address=172.16.1.2/30 interface=ether1
/routing ospf area add name=Area0 area-id=0.0.0.0 instance=ospf1
/routing ospf instance add name=ospf1 router-id=2.2.2.2 redistribute-connected=as-type-2
/routing ospf interface add interface=ether1 network-type=point-to-point
/routing ospf network add network=2.2.2.2 area=Area0
/routing ospf network add network=172.16.1.0/30 area=Area0
/mpls ldp "enabled=yes, lsr-id=2.2.2.2, transport-address=2.2.2.2"
/mpls ldp interface add interface=ether1 disabled=no
/interface vpls add name=vpls1 mtu=1500 remote-peer=1.1.1.1 cisco-style=yes cisco-style-id=173 advertised-l2mtu=1500 disabled=no
[admin@MikroTik] > interface vpls monitor 0
remote-label: 19
local-label: 37
remote-status:
transport: 1.1.1.1/32
transport-nexthop: 172.16.1.1
imposed-labels: 19
Switch#sh mpls l2transport vc detail
Local interface: Gi1/1/2 up, line protocol up, Ethernet up
Destination address: 2.2.2.2, VC ID: 173, VC status: down
Output interface: none, imposed label stack {}
Preferred path: not configured
Default path: active
No adjacency
Create time: 00:00:50, last status change time: 00:00:00
Signaling protocol: LDP, peer 2.2.2.2:0 up
MPLS VC labels: local 19, remote 37
Group ID: local 0, remote 0
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, send 0
how about your mtu?
Currently just 1500, I have tried using 1526 and 1998. When increasing the system MTU on the Cisco 3750 I kept getting an MTU mismatch error which from memory i was able to resolve by changing the MTU setting of the VPLS interface on the MT.
Would have to get the info when I am back in the office.
Try to have l2mtu to 1600 or higher. Put mpls mtu to … 1560, and have the vpls mtu at 1500
I believe it is a restriction of the current IOS version I have on the 3750ME switch.
Currently trying to get my hands on the correct version. Will post an update once I make more progress.
Ether3al
I have made some progress, but still not getting a usable link:
20:48:51: %LDP-5-NBRCHG: LDP Neighbor 2.2.2.2:0 (1) is DOWN (TCP connection closed by peer)
20:49:03: %LDP-5-NBRCHG: LDP Neighbor 2.2.2.2:0 (1) is UP
20:49:03: MPLS peer 2.2.2.2 vcid 173, VC UP, VC state UP
Switch#sho xconnect all detail
Legend:    XC ST=Xconnect State  S1=Segment1 State  S2=Segment2 State
  UP=Up       DN=Down            AD=Admin Down      IA=Inactive
  SB=Standby  RV=Recovering      NH=No Hardware
XC ST  Segment 1                         S1 Segment 2                         S2
DN     ac   Gi1/1/2(Ethernet)            UP mpls 2.2.2.2:173                  DN
            Interworking: none                   Local VC label 18
                                                 Remote VC label 53
                                                 pw-class:
Switch#show mpls l2transport vc detail
    Default path: no route
    No adjacency
  Create time: 00:02:32, last status change time: 00:00:09
    Targeted Hello: 1.1.1.1(LDP Id) -> 2.2.2.2
    Status TLV support (local/remote)   : enabled/not supported
      Label/status state machine        : activating, LruRruD
      Last local dataplane   status rcvd: DOWN(PW-tx-fault)
      Last local SSS circuit status rcvd: no fault
      Last local SSS circuit status sent: DOWN(PW-rx-fault)
      Last local  LDP TLV    status sent: DOWN(PW-tx-fault)
      Last remote LDP TLV    status rcvd: not sent
    MPLS VC labels: local 18, remote 53
    MTU: local 1598, remote 1598
  VC statistics:
