Won’t the MT connect to the Senao, or does it connect but not pass DHCP/Traffic?
What you said in the forum should really work, it is rather odd. You didn’t by any chance setup the Senao to use WPA instead of WEP? One more thing I can think of, is that if you’re using a 802.11b Senao AP (Prism2/2.5 wireless card), you may pickup problems with MT. Prism2/2.5 uses pre-2.9.6 firmware and apparently doesn’t support WEP, allthough Senao found a workaround for their AP’s.
I know it is rather odd, doesnt make sense at all…
And no no configuration mistakes on security side as we have tested this on many differant occasions myself and someone else.
As for the senao’s they are 802.11g radios with prism 2.5 chipset.
Why however can the senao connect to the MT using wep but not vise versa.
Senao Ap: Mode Bridge,point to multi-point,Cloning bridge,SSID - CITI-NET,Channel -7
Transmission Rate:Automatic,Access Point Density:High And No WEP Key.
Work perfect for Me.Only one problem Senao AP always send One Mac Address.
