MT connections limit
Hello
i’m using CCR1036 running 6.37.1 as a CGN router. I have around 10K NAT rules and about 100K connections and about 500Mbps traffic in each direction.I’m using one 10G interface for traffic in both direction and CPU does not exceed 10%.
On the bottom of the IP->Firewall->connections winbox window, it is printed that max connections is about 524000. Should I consider this value for sizing? Are there any other factors that I should take into consideration?
