I’m trying to do router on the stick for ESXi host. But i’m stuck with this one. I have port 24 connected to esxi, two vlans 33 and 44. From two virtual machines I can ping default gateway (MT with .1) but machines cannot ping each other. Can you please tell me what I’m doing wrong?
add name=br-1
add name=br-vlan-11
add name=br-vlan-33
add name=br-vlan-44
set [ find default-name=ether1 ] name=ether1-mt8-1
set [ find default-name=ether2 ] master-port=ether1-mt8-1 name=ether2-router-1
set [ find default-name=ether3 ] name=ether3-slave-local
set [ find default-name=ether4 ] master-port=ether1-mt8-1 name=ether4-slave-local
set [ find default-name=ether5 ] master-port=ether1-mt8-1 name=ether5-slave-local
set [ find default-name=ether6 ] master-port=ether1-mt8-1 name=ether6-slave-local
set [ find default-name=ether7 ] master-port=ether1-mt8-1 name=ether7-slave-local
set [ find default-name=ether8 ] master-port=ether1-mt8-1 name=ether8-slave-local
set [ find default-name=ether9 ] name=ether9-syno-2hd
set [ find default-name=ether10 ] master-port=ether3-slave-local name=ether10-syno-1hd
set [ find default-name=ether11 ] master-port=ether3-slave-local name=ether11-esxi-mgmt
set [ find default-name=ether12 ] master-port=ether3-slave-local name=ether12-mac
set [ find default-name=ether13 ] master-port=ether3-slave-local name=ether13-raspi
set [ find default-name=ether14 ] master-port=ether1-mt8-1 name=ether14-slave-local
set [ find default-name=ether15 ] master-port=ether1-mt8-1 name=ether15-slave-local
set [ find default-name=ether16 ] master-port=ether1-mt8-1 name=ether16-slave-local
set [ find default-name=ether17 ] master-port=ether1-mt8-1 name=ether17-slave-local
set [ find default-name=ether18 ] master-port=ether1-mt8-1 name=ether18-slave-local
set [ find default-name=ether19 ] master-port=ether1-mt8-1 name=ether19-slave-local
set [ find default-name=ether20 ] master-port=ether1-mt8-1 name=ether20-slave-local
set [ find default-name=ether21 ] master-port=ether1-mt8-1 name=ether21-esxi-4-4
set [ find default-name=ether22 ] master-port=ether1-mt8-1 name=ether22-esxi-4-3
set [ find default-name=ether23 ] master-port=ether1-mt8-1 name=ether23-esxi-4-2
set [ find default-name=ether24 ] name=ether24-esxi-4-1
set [ find default-name=sfp1 ] master-port=ether1-mt8-1 name=sfp1-slave-local
/interface vlan
add interface=ether24-esxi-4-1 l2mtu=1584 name=vlan-11 vlan-id=11
add interface=ether24-esxi-4-1 l2mtu=1584 name=vlan-22 vlan-id=22
add interface=ether24-esxi-4-1 l2mtu=1584 name=vlan-33 vlan-id=33
add interface=ether24-esxi-4-1 l2mtu=1584 name=vlan-44 vlan-id=44
/port
set 0 name=serial0
add bridge=br-vlan-11 interface=vlan-11
add bridge=br-vlan-11 interface=ether3-slave-local
add bridge=br-vlan-11 interface=ether9-syno-2hd
add bridge=br-vlan-33 interface=vlan-33
add bridge=br-vlan-44 interface=vlan-44
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu vlan-id=33
add tagged-ports=switch1-cpu vlan-id=44
/interface ethernet switch ingress-vlan-translation
add customer-vid=33 new-customer-vid=44 ports=ether24-esxi-4-1 sa-learning=yes
add customer-vid=44 new-customer-vid=33 ports=ether24-esxi-4-1 sa-learning=yes
add address=192.168.11.133/27 interface=vlan-11 network=192.168.11.128
add address=192.168.33.1/24 interface=vlan-33 network=192.168.33.0
add address=192.168.44.1/24 interface=vlan-44 network=192.168.44.0
/ip dns static
add address=192.168.11.131 name=raspi
add distance=1 gateway=192.168.11.129
/lcd
set backlight-timeout=2h default-screen=interfaces time-interval=hour
/lcd interface pages
set 2 interfaces=ether3-slave-local
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Warsaw
/system routerboard settings
set protected-routerboot=disabled
