MT eats memory
Look at this:
After reboot, it uses couple of megs of RAM, but constantly eats more and more.
I’ve arleady disabled conntracking but it didn’t change anything.
This MT acts as a bridge only (no routing, no NAT’ing, no DHCP, just bridge)
What can i do with this? It hangs after getting to 250 megs…
what version are you using? any fancy configuration?
Version 2.9.6… I guess i have to upgrade.
No, only few firewall rules…
There are 3 wireless, 2 ethernet and 1 tunnel interface, 2 bridges.
Disabling graphing doesn’t help either.
You must upgrade to 2.9.38.
More than a year old version and you GUESS you should upgrade? I’d say you have no rights complain at all unless you have upgraded :smiling_imp:
