MT, EOIP, and DHCP
I have two MTs connected via PPTP and EOIP. Each MT has a DHCP server handing out different IP (192.168.1.x and 192.168.2.x respectively). I am running into the problem where DHCP clients from one network are assigned addresses from the remote network… that’s not good :slight_smile:
How might I block DHCP from traversing the EOIP tunnel?
Thanks!
Firewall UDP Ports 67 and 68 to cross the EOIP Tunnel. The one end’s DHCP Server won’t see the requests from the other side and vice versa
