Getting error “The requested URL could not be retrieved”
The following error was encountered:
Invalid Request
However everything works fine if i disable the nat rule and place the proxy info into Internet Exploder. I am wondering if this is similar to what you encountered.
OK I have solved the issue with the proxy not loading pages for the end users. In the webmin under squid → Proxy and Networking. The proxy addresses and ports Option field needs the word “Transparent” without quotes. However I am running into an issues with the proxy timing out on pings when running the squid service, also clients are complaining that some pages will not load or that the internet is running very slow. If anyone has some insist on this issue please let us know, but i imagine this is a question for the squid forum at this point.
Intel(R) Xeon(R) CPU E5430 @ 2.66GHz, 8 cores
RAM: 15.86 GB total, 607.59 MB used
The hardware is not the issue. I think i found some threads about needing to upgrade to a new squid version, then something about webmin needed to be recompiled, but real work has side tracked me from this issue. I will post results when I get a working config.
