After login in hotspot page, browser hangs on " connecting to “ip address of hotspot” in status bar and staying on login page (Actually customers is log in but not redirecting to status page, which is very frustrating for customers)
After press F5 or refresh in browser it redirect to status page (which is ok,customers have internet)What happen?
All html have refresh line in their code (first line)
Have you made any modifications to the hotspot html that could be attributed to the login not working?
Eg: if you reset the html and try logging in with a username and password does it do the same thing or does it go straight through.
If it sits there with the default html then it sounds like theres a config problem on your device somewhere
If it goest straight through with the default html then it sounds like the problem is in your hotspot html somewhere.
