MT Load Balancing internal network
I have a MT and 4 ADSL routers connected on. I setup MT for load balancing (http://wiki.mikrotik.com/wiki/Load_Balancing). Everything works ok,but how can I access my internal network (behind MT)???
Thanks in advance…
you have to set policy routing for you - that you have to route traffic to you through one GW using routig marks, atleast i would try that. :unamused:
Thanks for your reply,but
can you be more specific ???
hope that helps:
http://www.mikrotik.com/testdocs/ros/2.9/ip/mangle.php
oh, you can do pptp or pppoe tunnel to your MT router and you will be inside :slight_smile:
