MT *NOT* Dropping Bit-Torrent
I’ve created an IP Firewall Chain rule, action=drop, for p2p=bit-torrent, in the PC-based Mikrotik that is acting as a transparent traffic shaper (bridge) for my WISP network. I’m currently using version 2.9.22.
Even after a reboot of the system, there is still one customer listed in IP Firewall Connections that has Bit-Torrent connections to the outside world marked as “Established”.
I want to completely drop Bit-Torrent traffic and should be able to do this. Any idea why it isn’t it working?
try bridge firewall maybe?
What is bridge firewall?
Ok, found IP Bridge Filter, and added chain=forward packet-mark=all_p2p action=drop. It didn’t solve my problem, the same customer has dozens of “established” bit-torrent connections still. I don’t see any traffic hitting this rule at all through Winbox.
It wont work right away, select all of the P2P marked connections and remove them - the rule will only take affect on new connections not ones that already exsist - They will hang around for 5 days IIRC
