So, we are about to get a DS3 from Qwest. It’s out first. They have quoted us $8000 for a Nortel DS3 router. This seems awfully high. Does Mikrotik have an enterprise solution for this? Is anyone currently using MT as a core router with a DS3 or greater link?
What is the setup? All I find in the forums is mention of an old card: SBE T3 PCI
If you don’t want to pay for a DS3 interface, you need to request Ethernet hand off. The only advantage to a DS3 is when you need to channelize a connection.
We’re using a MT on a 200Mbs fiber connection without any problems. It comes directly into a MT using a PCI-e 1Gbs fiber adapter; the ISP throttles it on their side. The throttle is elastic and we’ve went over the 200Mbs on several occasions, running at 220-225Mbs for several hours.
