MT - voip gateway
i’ve got question - i want to set up a voip gateway.
I don’t know how to start - i’ve got only a pc with mt lev. 4.
Should i buy anything else? any voip cards?
What software do i need else?
is there a tutorial for that?
please help. thanks in advance
I think you’re trying to make a tree from a rock.
This will not work.
But mikrotik has got voip support. I’ve read some posts about voip here and smbdy has got probably something that i want to make.
If mikrotik is not this what i want for that - what should i use instead?
regards
