MT VPN Connection
I have a problem with VPN Connection. hope anyone can help me solved this problem.
i have 2 gateways in my office, one gateway is , say, have public IP 202.148.99.34/27 . the other gateway is 202.148.99.30/27 . i have a Mikrotik VPN server with ip 202.148.99.28/27 (it’s on the same network with my 2nd gateway).
locally, i have a mikrotik that establish VPN connection to 202.148.99.28. when i use the gateway 99.34, it’s normally establish, but when i use the other gateway (99.30, that connect at the same network) it can’t establish at all, the error message is :
LCP Timeout waiting initial data
have anyone find out such problem? or is the VPN connection can’t be establish with the same network? or is there any missconfiguration in my setting?
Thanks for advance
