MT web server
Hi all,
I’m thinking tho build a web interface to our MT based CPEs (RB133/c).
The idea is to give to our customers (we are a WISP) the possibility to access limited functions on their CPE, e.g. firewall, LAN IP settings, port forwarding, etc…
Might this be possible with ROS? Web server in MT docs is covered only into hospot section… Any docs around?
Rgds
you may host web interface on your http-server, and access MTs via ROS v3 API
Thank you Chupaka, but this doesn’t help me…
What I would like to make is web interface to MT based CPE.
All MT systems can be managed via web by default, I’m trying to understand if is it possible to modify this web interface following my needs.
Rgds
That is not possible in any way.
That’s a bad news… :cry:
Is web server included in roadmap for further ROS releases?
If not, may it be included in the whislist?
It will be veeeery useful, to build a complete CPE solution.
Rgds
We already have some kind of web management interface. It’s very primitive, but we are working on improving it sometime.
Nice to read this from you Normis,
hope to see (in a near future) changelog that annonces such feature in a further ROS release.
I think that many WISPs that are using MT CPEs will really appreciate such capability.
Probably (may be I’m wrong :confused: ) CPE features (LAN IP address, port forwarding, etc..) might be changed via web interface, simply creating links to stored scripts that receive input parameters from web interface, where variables are specified into forms.
Rgds
