Hi all
I have an hp pda. When trying to get ip from mt 2.8 it can not.
This happens only on pda. On laptops its fine.
Any suggestion?
thanks
Hi all
Any suggestion?
thanks
Check if you have dhcp client enabled. Does it work with other dhcp servers?
I have a HP 6315 PDA/Phone.
It works GREAT with my MikroTik at work and at home !!
You may want to check the wireless setings IE MAC filtering, band etc.
My iPAQ is only “B” si i have to support it at both locations.
Craig
Hi
Yes, the pda works with other dhcp servers with
No problem. The mt is configured for hotspot.
Cookie enabled no wallgurden.
Is that what you have?
No I use it ad a “std client”.
It connects via 2.4 (atheros), dhcp and source NAT.
I have full local and internet access.
Authentication is be MAC address to the wireless access point.
(MT Lic. Lvl 5)
I have set it up under hot spot and it works as well, no specail setup.
Craig
