MT433AH with ubiquiti XR2 setup ..Help!!
Hello Everyone!
I’m very new to MT, I’ve just installed 433AH board with Ubiquiti XR2 card (AR5413 2.4ghz). I want to setup a PTMP network using Ubiquiti NS2/L as CPE. I just installed my MT radio & changed its mode to “ap bridge” & I was able to scan “MikroTik” (SSID) on client end using Ubiquiti NanoStation2. It also got connected at a good RSSI value (-45dBm). But, I cannot ping my MT Radio sitting on client side & vice-versa. Do I need to do some more configuration changes or anything … please help!!
thanks in advance. :slight_smile:
Rahul.
make a bridge and add ether1 and wlan1 ports.
Thanks for prompt reply buddy!!
I have added a bridge and added said ports (ether1 & wlan1). I can see traffic (Rx/Tx) on ether1 but only TX on bridge & wlan1 (only RX). I also tried enabling WDS Mode (dynamic) & used bridge I made as “Default WDS Bridge” and change my NS2 (CPE) to station wds mode.. but nothing changed. Do I need to check anything else??
thanks!
Rahul
man, read the wiki por ap bridge… ITS EASY. WDS?¿?! Nopes!
start looking a few of this in the wiki.
