MTP250-26V94-OD
Hi guys,
Just looking for some information regarding the MTP250-26V94-OD, I want to put an outdoor plug ABB 16A 2P+E Connector 250V onto the input AC end of the MTP250-26V94-OD.
Looking at the brochure it says AC powering (Max current) 3.5 A but the outdoor plug ABB is 16A is this safe to do?
Also is this device safe to install outside on a light pole exposed to weather?
Product code MTP250-53V47-OD / MTP250-26V94-OD
AC input & Full load 100-240 V
DC output 250 W
Operating temperature -40°C to +70°C
Certification CE, FCC, IC, IP67
IP67 Protected from immersion between 15 centimetres and 1 metre in depth
Of course, the plug will handle 16A - but the power supply will draw a maximum of 3.5A. You will only use 22% of rated handling power.
IP67 should do fine outdoors.
Thank you for quick reply
