It DOES work in real hardware with version 6.42.12.
It does NOT work in virtualized scenario, throwing error
failure: could not set mtu
I’ve tried this in Virtualbox and in GNS3(qemu) with the same error.
I’ve also tested newer versions in GNS3(6.45 and even 7beta) with same error.
In Internet there are videos showing the same commands I use working in GNS3, so i’ve downloaded an older version (6.34.6) and the commands work ok in GNS3.
Thanks for the reply.
I’ve been trying all the other previous long-term releases and nothing worked.
I will try decreasing the MTU too and see how it goes.
The same for me 1496 was the maximum MTU without error. Everything works as expected. Don’t know why!!
Without using a bridge I had also to reduce MTU to 1496.
Do you know which was the root cause of this issue? I’m trying to replicate a real scenario on Mikrotik CHR with GNS3, the default 1500 mtu isn’t working. Thanks!
