MU-MIMO?
Hi Guys
I see that Mikrotik is supporting 802.11n - MIMO
Is this for ptp links or can we use it on our distribution sectors and make use of MIMO for clients?
Yes, it is ready for both PtP and PtMP.
Tom
Great,
Does the CPE have to have 2x antennas aswell? or can the CPE have 1 antenna that connects to 2x sectors? like a SIMO setup?
I don’t think MIMO on the tower would really show much benefit without MIMO on the ground as well. It certainly wouldn’t help as much.
I have wondered if a rubber duck omni on the client side would help on good shots, 5dBi or so.
Two panels would be better, but a 15 dBi panel with a 5-7 dBi omni on short range links would, theoretically, improve the link, and not increase cost much.
I was thinking Rootenna or ARC enclosure with an NF bulkhead and a rubber duck, extra $25 for the CPE. I can’t see where it would really hurt.
Good idea, but its the long links that need the improvement :stuck_out_tongue:
MIMO is what dual polarity antennas can be used for.
ARC has a 5GHz panel that is 23/24dBi dual pol.
http://www.roc-noc.com/pdf/arc/ARC-ID5823B88.pdf
Laird has some dual pol dishes up to 32dBi.
http://www.roc-noc.com/pdf/laird/HDDA5W_DataSheet.pdf
Tom
thanks Roc Noc
Could you just clarify: for MIMO do the antenna’s need to be opposite polarity or the same?..ie 1x horizotal + 1x vertical or 2x vertical?
My one supplier says they need to be the same but I dnt agree with that
they can be both opposite or same polarity.
same polarity makes better sense.
UBNT802.11n products are opposite polarities.
Then why does UBNT have them opposite if same polarity is better?
:smiley:
haha oh I see :stuck_out_tongue:
Could you give me a quick technical reason why same polarity is better?
thanks
you can ask Doush what he meant, I didn’t comment yet.
The chains need best seperation or isolation.
Having different polarities nets you easy seperation.
Alternatively you can space your antennas for seperation, but with this you need ALOT of seperation.
N is designed for multipath and seperation nets you a better multipath senario, however seperation on towers is difficult to acheive without a massively high tower, and extremely good coax.
Thanks, is LMR400 good enough coaxial? How far is ALOT of separation? 2 meters apart? or are you referring to channels?
It Largely depends on the type of antennas used.
I would recommend in most cases a minimum of 6 meters or more.
Id est one antenna bi-polar is impossible to work properly, right? Even different antennas at 1-2m…
We have problems with interference in such cases. Usually 1.20-1.40m diam. antennas @ 5GHz mimo or not.
sorry, im not sure what you mean?
