much difference between tx / Rx
I am realizing that I have many clients who have increased the dBm after a while, for example:
I have a cpe that had 49/50 dBm tx / rx
Now the same cpe has 49/59 dBm Tx / Rx
we have tried to reorient the antenna and we have not achieved anything, changed the frequency and we have even put another antenna in the client’s house cpe
I currently use the sxt lite ac 5 antenna
any advice?
Try to downgrade if you updated.
If nothing changes, it means you can’t transmit well as before because of noise, remember you aren’t using Dynadish but SXT.
I had not updated yet. I have set another frequency and it remains the same …
the max distance would be 1500m at the most. There is direct vision. As much as I move the antenna I do not get to equal the tx / rx, the best I could have left it with a difference of 7 dB.
I have seen that it also happens with other clients that are connected to other nodes.
How can I match the tx / rx?
Are the transmitters on both end same? If not, isn’t that the expected result, as transmit energy will be emitted / concentrated differently?
Yes, they are the same.
