Mullvad VPN Docker Image on RouterOS - seeking advice
Is anyone successfully running Mullvad VPN Docker Image on RouterOS and using their obfuscation methods along with DAITA tech? Simple WireGuard config within RouterOS can't provide that and Mullvad's API is required for such methods.
I assume I should just follow common Docker Image deployment procedures or is there anything else I should know? I primary want to know whether it is possible and DAITA works.
