Multi BGP Support or Not
Dear Sir
Wanted to Confirm is there any way to run two bgp in MT.
and wants to know bgp configuration in detail.
Please post some other websites linke except MT.
Regards
Damanpreet Singh
yes, you can run multiple instances, as well as multiple peers.
Thanks for the feedbackj
but how sir , when i am trying for add instance it is not enabling me to add because i had not putted any routerID
wht is router id and wht should i put there.
As Router ID you can put any number that recognizes your router when enstablishing peerings. I usually use the IP of the router as Router ID, but it’s not mandatory.
