Multi client subnets, multi gateways
Still an issue..
In a setup of one MT Gateway, One wireless card(Bridge Mode -WDS- towards wireless network) and one ethernet. Both Bridged.
IPs:
192.168.1.1/24
192.168.2.1/24
192.168.3.2/24
192.168.4.2/24
All set to Bridge Interface/
Clients connect to APs on the Wireless network. Different IP ranges.
Multiple Internet routers with different internal IP ranges.
Router1: 192.168.3.1/24
Router2: 192.168.4.1/24
Example:
Client1: 192.168.1.2/24 gateway 192.168.1.1
Client2: 192.168.2.2/24 gateway 192.168.2.1
Need to route client1 to router1
Need to route client2 to router2
Set separate masquerading for 192.168.1.0/24 and 192.168.2.0/24
Set separate Mangle routing-mark rules for source-ip-address 192.168.1.0/24 and 192.168.2.0/24
Set static routing (default Gateways) for above routing marks to desired gateways…
IS THIS SETUP CORRECT OR AM I MISSING SOMETHING COZ I can’t get it to work???
MT or Anyone Please help.
Doesn’t look right to me, you’re trying to use routing rules over a bridge.
Assuming your Internet routers are on the Ethernet interface there are two possible solutions:-
Scenario 1
Delete the bridge.
Add 192.168.1.1/24 and 192.168.2.1/24 to the Wireless interface.
Add 192.168.2.2/24 and 192.168.3.2/24 to the Ethernet interface.
If required, add a default route so that the Router itself can access the Internet.
Scenario 2
Alternatively, leave the bridge, but delete all 192.168.3.0 & 192.168.4.0 addresses and set your Internet routers to 192.168.1.0 & 192.168.2.0 addresses, finally remove NAT/Masquerade.
Forget Scenario 2, that won’t work, go with my original thoughts for Scenario 1.
Final comment, I wouldn’t bother masquerading it gives no benefit, most Internet Routers do NAT/Masquerading at that point. No benefit in using more than one level of NAT, just use plain routing.
Thx for your response. Definitely problem is over the bridge. Believe also adding another network card and setting the 192.168.3 and 4 range to the new NIC interface should help, coz can’t really change IPs on Internet routers. They are actually real IPs, the 192.168.3 and 4 are just examples. It is actually unacceptable to bridge anything with the Internet… Security and Internet User Policy agreements. Anyway, just wanted to try. But thanks a lot.
