I want to deploy my new edge router.
It is safe to enable multicore support in MT 3.2 (c2d on some supermicro mobo).
Is there any known problem in this MT version?
Are there some positive/negative experiences?
thanx
kubiik
thanx
kubiik
its hit or miss. If you are going to do something that generates alot of processes. Web Caching, PPPoE sessions etc. then no, else you can try. If it crashes or lockes up, turn it off and see if the problem goes away
I think another option is to see how much CPU one core uses, if it is not using much in the one core, leave it off!
I know this will be fixed soon.
