Multi DHCP clients on same WAN port
No.
Haha Jarda you crack me up.
The Op asks a question,and you gave him the clear answer.
So cruel :wink:
Is it a dual hatted answer No No, is it implicitly a No Yes or implicitly a Yes No ??
OR perhaps we will never know as there is that outside chance that during the typing of a response you experienced a medical emergency and accidentally hit the submit key on the way to the floor??? (which begs the question why bother typing this because you may never answer).
Well, if it can be any way, I didn’t test it lately, but there’s VRRP hack.
You know me… I give usually the simpliest answers.
Better to bridge the wan with the devices that should receive the public ip addresses so they will be able to get them directly.
I assume that’s not desired for some reason, because otherwise it would be the most direct and obvious approach.
