How can i make the interface publish mac form the other interface.
i have an APPLETV on LAN2 and IPHONE on wifi but thay cant talke to each other. but i kan ping them so i think thay scan for mac.
> /ip dhcp-server print
# NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 LAN LAN2-master dhcp_Ether 3d yes
1 WIFI-IN WIFI dhcp_Wifi 3d yes
/interface> print
# NAME TYPE MTU L2MTU MAX-L2MTU
0 R WAN ether 1500 1524 1524
1 R LAN2-master ether 1500 1524 1524
2 R LAN3 ether 1500 1524 1524
3 R LAN4 ether 1500 1524 1524
4 LAN5-slave ether 1500 1524 1524
5 R vpn.Anonine.net pptp-out 1460
6 pptp-in1 pptp-in
7 R WIFI bridge 1500 1524
/ip address> prin
# ADDRESS NETWORK INTERFACE
0 ;;; ETHERNET
192.168.88.1/26 192.168.88.0 LAN2-master
1 D 82.196.108.172/23 82.196.108.0 WAN
2 ;;; WIFI
192.168.88.65/26 192.168.88.64 LAN3
3 D 188.126.92.242/32 188.126.80.0 vpn.Anonine.net
That is what proxy-arp partially does, but you probably need to try putting everything on the same bridge if your devices truely only communicate on a layer2 (mac).
However, are you sure that your devices require a layer 2 communication? It’s hard to believe that any modern networked devices won’t work over stardard TCP/IP Layer 3.
it works over tcp but, like the ipone scans the network for a mac range 58:55:CA:::** that is the APPLETV. and when it finds it it connect to the ip. if the iphone cant see the mac how can it tell if one ip or a nouther ip is the appletv.
its same whit menny outher products.
If that is truely what it requires, then you may need to put it all on the same bridge. A lot of network printers work that way as well where they look at mac addresses, but they will allow you to manually type in the IP address in the case they are on separate networks. So, you do not have that option with the iPhone-to-AppleTV?
nopp, its appels own DNAL protocol, like i said i have a bridge and the second dhcp-server is using that as a interface and the firs dhcp-server uses Lan2 interface. so how can i put all 3 interface in one bridge and make LAN3,4 to get ip from dhcp2 and lan2 get from dhcp1.
Why do you want 2 different ip ranges for devices on the same network? You can only have 1 dhcp server on a network. So, you could let all your devices pull from the same dhcp addresses, and you could assign specfic addresses to certain mac addresses in the dhcp server if you wanted some devices to have forced addresses.
i need it for this setup all the wifi trafic is using a pptp interface and then all the ips in that range takes that way.
how can i else select who shuld use what connection?
You can choose in interfaces instead of src addresses. Even in bridge, you can use specific interfaces. In the bridge setting, make sure to enable “use firewall” so the traffic goes through the rules per interface:
instead of src-address=x.x.x.x/x you can use bridge-in-interface=aaaaaaa to pick out the specific wifi connections (not “in-interface”, make sure to use “BRIDGE in interface”. Its on the second tab in winbox instead of the first box).
