multi fifo queues
Running a core router rb1100Ah2x at about 100 megabits prime time download, 20 megs up. This router does nat and connection tracking.
Its connected to another identical router that does not do nat.
There is a bonded link between the first router and the second over two 100 megabit ethernets. Does it matter which two ethernets on each router are used to bond? I think 2 and 3 on router 1 is bonded to 3 and 10 on router 2.
Am I supposed to change the type of interface hardware queue on these routers to use both cpus? I read too much,
understand little.
Its presently set to the default hardware only queue.
cpu load seems balanced.
Thanks Homer
