Hey all - I am trying to configure BGP with MetalLB to achieve load-balancing in my Kubernetes cluster.
So far, I have set up the following:
My RouterBoard has a BGP instance 65530 on the router
In between the Kubernetes cluster and the router is a managed switch with L3 routing between VLANs, so the BGP peers are set up as multi-hop
Here are the routes on the L3 switch: (the cluster nodes that I’m trying to load balance are in the VLAN20 with subnet 10.20.0.0/16)
Protocol Destination Network Next Hop Distance Metric Interface Name
Static 0.0.0.0/0 10.0.0.1 1 0 VLAN1
Connected 10.0.0.0/24 10.0.0.2 0 1 VLAN1
Connected 10.20.0.0/16 10.20.0.2 0 1 VLAN20
Here is the BGP peer setup:
/routing bgp peer
add multihop=yes name=peer1 remote-address=10.20.10.1 remote-as=65529 ttl=default
add multihop=yes name=peer2 remote-address=10.20.10.2 remote-as=65529 ttl=default
add multihop=yes name=peer4 remote-address=10.20.10.4 remote-as=65529 ttl=default
There is a connection established between all the peers and they successfully advertise routes:
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADS 0.0.0.0/0 x.x.x.x 1
1 ADC 10.0.0.0/16 10.0.0.1 bridge 0
2 A S 10.10.0.0/16 10.0.0.2 1
3 A S 10.20.0.0/16 10.0.0.2 1
4 A S 10.30.0.0/16 10.0.0.2 1
5 ADC x.x.x.x/x x.x.x.x ether1 0
6 ADC 172.16.0.0/16 172.16.0.0 bridge 0
7 ADb 172.16.100.1/32 10.20.10.1 20
8 Db 172.16.100.1/32 10.20.10.2 20
9 Db 172.16.100.1/32 10.20.10.4 20
Note the 172.16.100.1 route dynamically added by the BGP peers. When I ping this address it hits the router, but immediately drops the packet. I am trying to get this IP to route to the peer IP in order to load balance connections.
Currently this 172 IP is not working, i have also tried a cidr in the VLAN 20 subnet, which didnt work, as well as a cidr in the same overall subnet. Not sure what I’m missing.
