multi microtik management tool
i would likt to see a easy management tool for mikrotik.
I manage about a 20 mikrotik routers at the moment and it is realy becomming a pain in the …
i would like to see something like http://www.solsoft.com/
it supports all the major routers/firewall
thanks for the suggestion. we are already working on some things similar to this
This would be very usefull. I manage 18 mikrotik routers on our network, with a few hundred pppoe connections.
I would suggest at least some SNMP v2 read/write support so we can build our own utilities for web based monitoring/management.
I second the motion for easier management of multiple units. I would like to see the ability to select features in ONE router and “automatically” add the feature to one or more other routers. For example, it would be nice to be able to add a firewall setup to one router, check it out and then migrate it “automatically” to other MTs.
Likewise, the ability to “clone” a MT unit would be a great feature.
One feature I liked in the Aironet (now Cisco) wireless equipment was the software distribution feature.
When you have large network, it makes a lot of sense to load new software on one of the units, and have it distribute it to others.
This is especially useful if/when you plan to install new “incompatible” features such as the different revisions of the nstreme package. :slight_smile:
Daniel
We are working on a system management tool that would have this feature.
John
please… I manage 10 routers… and firewall policies change frequently… I have to update all of them almost everyday… really pain in…
Hello all,
are there any news to this topic?
I can’t find a tool from MikroTik which meets the requirements mentioned.
Best regards
Rene
Well, they were working on it in 2004, so it must be complete by now.
Ubiquiti has such a tool and it would be awesome to have for Mikrotik hardware.
HA feature without having to use scripting would be very nice as well.
Will this management system be released along with RouterOS v.7 software?
https://www.youtube.com/watch?v=izQB2-Kmiic
Check out Unimus:
https://unimus.net/
It will do Mass Config Push, change detection, diffs, network-wide config search, etc.
You can easily upgrade RouterOS across the network.
Here is an article on network-wide RouterOS update:
https://unimus.net/blog/network-wide-mikrotik-routeros-upgrade.html
You can use Kiwi CatTools. Very good tool without limit devices and multivendor support
https://www.solarwinds.com/kiwi-cattools
https://support.solarwinds.com/Success_Center/Kiwi_CatTools/Kiwi_CatTools_3.11_Administrator_Guide/030_Devices
