Multi Pools on DHCP Server
Dear All,
I have HP V1910-24G switch. It is L3 core switch, but doesn’t have DHCP Server feature on it. So I must setup DHCP relay on all VLAN interfaces to my MikroTik. But i want to know if MikroTik router can provide multi pools on the same interface on MikroTik to VLAN interfaces HP V1910-24G).
Please help me.
Thank you.
Yes for sure tested and running!
Another, perhaps cleaner soluton than running DHCP relay, would be to establish trunk port between HP switch and a Mikrotik device. Then ROS could run DHCP servers natively on each VLAN. The only thing to care about would be to configure firewall which would block any routing between VLANs (HP switch is supposed to do that if I understand correctly).
