Multi PPPoE sessions
Good morning,
To combine multiple DSL connections we use the multi ppp function of the PPPoE. Lately i’m experiencing a few issues with this solution. To setup the pppoe session we use the following code:
/interface pppoe-client
add add-default-route=yes disabled=no interface="ether1 - WAN,ether2 - WAN,ether3 - WAN" keepalive-timeout=60 max-mru=1472 max-mtu=1472 mrru=1600 name=pppoe-out1 password=xxxxx use-peer-dns=yes \
    user=xxxx
Sometimes mostly after KPN does maintenance in the night and in the morning there are to many active sessions. For example, interface 1, interface 2, interface 3 are WAN ports. So basically there should be 3 active links. The only problem is that it builds up 6 or 8 or 10 or 19 active links sometimes. The logging displays the following:
9832	Nov/02/2018 09:35:06	memory	pppoe, ppp, info	pppoe-out1.1: initializing...
9833	Nov/02/2018 09:35:06	memory	pppoe, ppp, info	pppoe-out1.1: waiting for packets...
9834	Nov/02/2018 09:35:06	memory	pppoe, ppp, info	pppoe-out1: authenticated
9835	Nov/02/2018 09:35:06	memory	pppoe, ppp, info	pppoe-out1.1: connecting...
9836	Nov/02/2018 09:35:06	memory	pppoe, ppp, info	pppoe-out1: connected
9837	Nov/02/2018 09:35:06	memory	pppoe, ppp, info	pppoe-out1.1: authenticated
9844	Nov/02/2018 09:40:39	memory	pppoe, ppp, info	pppoe-out1: terminating...
9845	Nov/02/2018 09:40:39	memory	pppoe, ppp, info	pppoe-out1: disconnected
9846	Nov/02/2018 09:40:39	memory	pppoe, ppp, info	pppoe-out1: initializing...
9847	Nov/02/2018 09:40:39	memory	pppoe, ppp, info	pppoe-out1: connecting...
9848	Nov/02/2018 09:40:39	memory	pppoe, ppp, info	pppoe-out1.1: terminating... - administrator request
9849	Nov/02/2018 09:40:39	memory	pppoe, ppp, info	pppoe-out1.1: disconnected
9850	Nov/02/2018 09:40:39	memory	pppoe, ppp, info	pppoe-out1.1: initializing...
9851	Nov/02/2018 09:40:39	memory	pppoe, ppp, info	pppoe-out1.1: waiting for packets...
9852	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1: terminating... - failed to authenticate ourselves to peer
9853	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1: disconnected
9854	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1: initializing...
9855	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1: connecting...
9856	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1.2: initializing...
9857	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1.2: waiting for packets...
9858	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1: authenticated
9859	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1.1: connecting...
9860	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1.2: connecting...
9861	Nov/02/2018 09:40:40	memory	pppoe, ppp, info	pppoe-out1: connected
9862	Nov/02/2018 09:40:41	memory	pppoe, ppp, info	pppoe-out1.1: authenticated
9863	Nov/02/2018 09:40:44	memory	pppoe, ppp, info	pppoe-out1.2: terminating... - failed to authenticate ourselves to peer
9864	Nov/02/2018 09:40:44	memory	pppoe, ppp, info	pppoe-out1.2: disconnected
9865	Nov/02/2018 09:40:44	memory	pppoe, ppp, info	pppoe-out1.2: initializing...
9866	Nov/02/2018 09:40:44	memory	pppoe, ppp, info	pppoe-out1.2: connecting...
9867	Nov/02/2018 09:40:48	memory	pppoe, ppp, info	pppoe-out1.2: terminating... - failed to authenticate ourselves to peer
9868	Nov/02/2018 09:40:48	memory	pppoe, ppp, info	pppoe-out1.2: disconnected
9869	Nov/02/2018 09:40:48	memory	pppoe, ppp, info	pppoe-out1.2: initializing...
9870	Nov/02/2018 09:40:48	memory	pppoe, ppp, info	pppoe-out1.2: connecting...
9871	Nov/02/2018 09:40:48	memory	pppoe, ppp, info	pppoe-out1.2: authenticated
9872	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1: terminating...
9873	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1: disconnected
9874	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1: initializing...
9875	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1: connecting...
9876	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1.1: terminating... - administrator request
9877	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1.1: disconnected
9878	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1.2: terminating... - administrator request
9879	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1.2: disconnected
9880	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1.1: initializing...
9881	Nov/02/2018 09:41:41	memory	pppoe, ppp, info	pppoe-out1.1: waiting for packets...
9882	Nov/02/2018 09:41:43	memory	pppoe, ppp, info	pppoe-out1: terminating... - failed to authenticate ourselves to peer
9883	Nov/02/2018 09:41:43	memory	pppoe, ppp, info	pppoe-out1: disconnected
9884	Nov/02/2018 09:41:43	memory	pppoe, ppp, info	pppoe-out1: initializing...
9885	Nov/02/2018 09:41:43	memory	pppoe, ppp, info	pppoe-out1: connecting...
9886	Nov/02/2018 09:41:43	memory	pppoe, ppp, info	pppoe-out1.2: initializing...
9887	Nov/02/2018 09:41:43	memory	pppoe, ppp, info	pppoe-out1.2: waiting for packets...
9892	Nov/02/2018 09:41:46	memory	pppoe, ppp, info	pppoe-out1: terminating... - failed to authenticate ourselves to peer
9893	Nov/02/2018 09:41:46	memory	pppoe, ppp, info	pppoe-out1: disconnected
9894	Nov/02/2018 09:41:46	memory	pppoe, ppp, info	pppoe-out1: initializing...
9895	Nov/02/2018 09:41:46	memory	pppoe, ppp, info	pppoe-out1: connecting...
9896	Nov/02/2018 09:41:46	memory	pppoe, ppp, info	pppoe-out1.3: initializing...
9897	Nov/02/2018 09:41:46	memory	pppoe, ppp, info	pppoe-out1.3: waiting for packets...
9898	Nov/02/2018 09:41:48	memory	pppoe, ppp, info	pppoe-out1: terminating... - failed to authenticate ourselves to peer
9899	Nov/02/2018 09:41:48	memory	pppoe, ppp, info	pppoe-out1: disconnected
9900	Nov/02/2018 09:41:49	memory	pppoe, ppp, info	pppoe-out1: initializing...
9901	Nov/02/2018 09:41:49	memory	pppoe, ppp, info	pppoe-out1: connecting...
9902	Nov/02/2018 09:41:49	memory	pppoe, ppp, info	pppoe-out1.4: initializing...
9903	Nov/02/2018 09:41:49	memory	pppoe, ppp, info	pppoe-out1.4: waiting for packets...
9904	Nov/02/2018 09:41:51	memory	pppoe, ppp, info	pppoe-out1: terminating... - failed to authenticate ourselves to peer
9905	Nov/02/2018 09:41:51	memory	pppoe, ppp, info	pppoe-out1: disconnected
9906	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1: initializing...
9907	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1: connecting...
9908	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1.5: initializing...
9909	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1.5: waiting for packets...
9910	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1: authenticated
9911	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1.1: connecting...
9912	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1.2: connecting...
9913	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1.3: connecting...
9914	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1.4: connecting...
9915	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1.5: connecting...
9916	Nov/02/2018 09:41:53	memory	pppoe, ppp, info	pppoe-out1: connected
9917	Nov/02/2018 09:41:54	memory	pppoe, ppp, info	pppoe-out1.5: authenticated
9918	Nov/02/2018 09:41:55	memory	pppoe, ppp, info	pppoe-out1.1: terminating... - failed to authenticate ourselves to peer
9919	Nov/02/2018 09:41:55	memory	pppoe, ppp, info	pppoe-out1.1: disconnected
9920	Nov/02/2018 09:41:55	memory	pppoe, ppp, info	pppoe-out1.1: initializing...
9921	Nov/02/2018 09:41:55	memory	pppoe, ppp, info	pppoe-out1.1: connecting...
9922	Nov/02/2018 09:41:56	memory	pppoe, ppp, info	pppoe-out1.2: terminating... - failed to authenticate ourselves to peer
9923	Nov/02/2018 09:41:56	memory	pppoe, ppp, info	pppoe-out1.2: disconnected
9924	Nov/02/2018 09:41:56	memory	pppoe, ppp, info	pppoe-out1.2: initializing...
9925	Nov/02/2018 09:41:56	memory	pppoe, ppp, info	pppoe-out1.2: connecting...
9926	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.4: terminating... - failed to authenticate ourselves to peer
9927	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.4: disconnected
9928	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.4: initializing...
9929	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.4: connecting...
9930	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.2: authenticated
9931	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.4: authenticated
9932	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.3: terminating... - failed to authenticate ourselves to peer
9933	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.3: disconnected
9934	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.3: initializing...
9935	Nov/02/2018 09:41:57	memory	pppoe, ppp, info	pppoe-out1.3: connecting...
9936	Nov/02/2018 09:41:58	memory	pppoe, ppp, info	pppoe-out1.1: terminating... - failed to authenticate ourselves to peer
9937	Nov/02/2018 09:41:58	memory	pppoe, ppp, info	pppoe-out1.1: disconnected
9938	Nov/02/2018 09:41:58	memory	pppoe, ppp, info	pppoe-out1.1: initializing...
9939	Nov/02/2018 09:41:58	memory	pppoe, ppp, info	pppoe-out1.1: connecting...
9940	Nov/02/2018 09:41:58	memory	pppoe, ppp, info	pppoe-out1.1: authenticated
I’ve build an disable/enable script to reset the pppoe session, after running this a few times its back to 3 links again.
Current firmware is 4.42.7, but also tested on 4.43.2, 4.43.4.
Anyone any idea’s how to solve this? or in which direction i need to look. I’ve got a feeling that the remote pppoe server is not reacting fast enough, but i cant pin point this.
Thanks in advance!
Just an idea because i never tried. Try lowering keep-alive-timeout. If more sessions are created try rising.
Hi, thank you for the suggestion. I lowered it to 5 sec and this morning the same issue again, 7 active links instead of 3.
Do you use a profile on those connection? I the profile you can set hard time limit to end a connection. There is also a option to use ‘only one’ and then you could use a profile for each three connections.
Did anyone find a solution to this problem?
I keep getting random disconnections within the same day :confused:
