Hello
Can I input 2 ISPs which they use PPPOE to supply Internet (may they use same or different address spaces), to 433ah router, and I select any service depend on my PPPOE request.
Regards
Hello Sir
I means, according to a broadband connection account (user name/password) which will dial in.
i.e. when the user uses ISP1 user/password, he will connect to ISP1 network,
or when the user uses ISP2 user/password, he will connect to ISP2 network
Look at these pages on Mutiple WAN and sourced based routing
http://forum.mikrotik.com/t/multi-wan-load-balancing-adsl-dsl-cable-modem/26959/1
http://wiki.mikrotik.com/wiki/Load_Balancing_over_Multiple_Gateways
why do you need RB if your users use ISP’s credentials to connect?..
or what do you mean? where are user accounts stored?
