Multi VLAN, VLAN Trunking on Point-to-Multipoint Bridge
Hi everybody,
(1) Has anybody deployed a Point-to-Multipoint Bridging using MT ?
Can you give any advice regarding such configuration ?
(2) Does MT support VLAN Trunking (using the new 2.8.15) ?
MT 2.8.15 :
VLAN - IEEE802.1q Virtual LAN support on Ethernet and WLAN links;
multiple VLANs; VLAN bridging
(3) How to deploy VLAN bridging on a Point-to-Multipoint configuration?
Need advice.
Thank you
1: afaik it’s not possible to bridge over an wlan interface in station mode.
try EoIP tunnel
2: its mentioned in the docs, but haven’t used it yet.
3: i would guess, that vlan tagging will work through the EoIP tunnel.
In v2.8.15, there is a station-bridge mode, but you have to have MikroTik on all clients.
John
nice!
so it becomes possible to build a bridged environment without using EoIP tunnels? simply stuffing all the wlan interfaces and ethernet interfaces one wants to in a bridge?
and it is not wds?
any disadvantages?
it seems not to be in the documentation or changelog, yet .
